IFC translators crash
Good morning/afternoon/evening (depending on your location)- I am having a problem whenever I open and work in the IFC Translation Setup while in Archicad 14. The only translator I have when I open the Setup is the General Translator. I am able to add more translators, but after I do this or make any other changes in the Setup, when I hit the 'Save Settings & Close" the application crashes with the dreaded bug reporter popping up on my screen. Has anyone else had this problem and if so, are there steps to fix it? Thanks for your help.
Andy Bartos
Breslin Ridyard Fadero Architects
Allentown, PA
1 Reply 1
COuld it be that there are some permission issues on your computer with the folders containing the IFC Translator files?
