ZM1
M3 MacBook Pro and OS 14.0 Sonoma
Compatibility with AC27+ Enscape?
When to expect?
Regards,
Zarko
5 Replies 5
ZM1
Sorry, additional question:
How is going to work my old USB licence key on USB c M3 mac book ports?
Thanks
Z.Madunic
Craig Bagley
I would guess a USB-C to USB adapter (which I'm currently trying to confirm w/Apple myself)
AC27 USA/Build 5030 16" MBP
_nique_
USB-C to USB-A adapter works without any issues - I've been using the dongle this way on my MacBook for years.
I'm also very interested in the compatibility and performance of the new M3 processors with ArchiCAD and Enscape, especially because of the hardware ray tracing. Perhaps someone can already assess this?
ArchiCAD 24-29, BIMcloud
Win 11, Core 7 Ultra 270K Plus, 64gb DDR5, RTX3060
Macbook M3 Pro
As others said, a USB-A adapter is all that is needed to use the USB-A Codemeter, or any other USB-A devices.  If you have other devices (scanner, printer, older disk drives, etc) best solution is a port expander / hub / dock.
I'm not sure why the questions about M3 compatability.  There is nothing architecturally or software-wise unique about the new M3 MacBook Pro vs the M2 series (or M1 for that matter) other than more cores, speed, and slower memory bandwidth.  Nothing that would make anything NOT run on an M3 that runs on an M2 or M1.
Sonoma is the only issue, not the M3.  For updates on issues with Sonoma... visit this article:
https://community.graphisoft.com/t5/Installation-update/macOS-14-Sonoma/ta-p/385787
This isn't the place for Enscape questions as it is not a Graphisoft product.  Visit their forums for Sonoma compatibility questions.
Eduardo Rolon
USB-A to USB-C Adapter have always worked since they removed the USB-A port with the 2016 Macbook Pros with Touchbar.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
