Problem - Automatic Offset
I have problem with my ArchiCad 16 student version. I click with mouse somewhere in the space, but it doesn't do the point there, where I clicked. It seems, that it offsets everything for about ~300mm.
I've tried to uninstall my 16 version, and install it again; I've tried to install version 15, but again and again the same problem. In other programs it doesn't do this only in ArchiCad.
Please Help me, I'm starting to be very desperate
6 Replies 6
Eduardo Rolon
Check that you don't have "Snap to Grid" on
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
No I tried this, but always the same problem
Eduardo Rolon
Sometimes outdated Video Drivers might cause that issue.
AC29 US/INT -> AC08
Ok I've tried that but it seems that it didn't solved my problem 😕 But thanks for your hint
TMA_80
Seems really strange, beside the graphic driver, have tried to see if the mouse settings have any effects?
Not sure that it will work, but have you tried "New& reset all" ( alt+file menu)
AC12_27 |Win11_64bit|
Yes I've tried this too, but it's still bad
