Installation & update
Railing tool
Hello
I just started using ArchiCAD a week ago. I am about to make railing for the balcony area, and realized I don't have the railing icon on the tool bar, which is supposed to be right after stair icon on tool bar. Does anyone know how I can get the railing icon, please?
12 REPLIES 12
Laura wrote:
If your on AC12, you can also use the Curtain Wall Tool (although I have not tried this personally).
I tried to do so, but the curtain wall tool doesn't allow heights less than 1.00 meter. isn't it so?
David Maudlin
When initially placing the Curtain Wall the limit is 1 meter, but can be reduced after initial placement using the Elevation panel (t & b) in the Info Box, or the Geometry and Positioning panel in the CW Selection Settings.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Ferenc_Traser
Graphisoft Alumni
Graphisoft Alumni
And there is one now!
