Installation & update
STAIR PROBLEMS.. WHAT ELSE?
hi
im trying to build stairs and i have many problems
i want the stair to be filled under the treads. is there an option from the stairmaker or i have to do the stair with slabs or mesh?
2) i want the tread numbers to appear in floor plan in the stairs that i create from scratch sush us the ones that are ready in library
3) i also want the stair above the cut to be in dashed lines both the treads and the contour line
appreciate any help
8 REPLIES 8
Petros Ioannou
Dear Vivi,
1) a.Draw walls below your stair and use Solid Element Operation to subtract (with Upwards extrusion) the stair from tha walls.
b. If you own Archistair you can create a solid stair.
2)Archistair
3)Archistair
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
hi
ellinika den milas? eida thessaloniki ekei
ki ego thessaloniki eimai
anyway mabe not
this archistair is unique or there are many versions many companies?
thank you for your answer
Rakela Raul
http://www.cadimagetools.com/home.php?page=products&productID=170
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Petros Ioannou
Mia xara ta milaw, apla tha htan ageneia na mhn katalavainoun oi alloi tipota... private milame ellhnika.
Archistair is an addon developed by Cigraph. www.cigraph-store.com has all the info u need , plus a demo (you can only check the menus AFAIK)
Petros
32 GB 2400 MHz DDR4
ki ego to skeftika meta !
thank you very much
i have archistair 1.09. it says archicad plugin a friend of mine just bought it
this is the one?
too many questions eh? im sorry
thats the last one
Djordje
You should also check the ArchiStair web site for updates.
There was a problem with the Student version, check in Other Products, do a search.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
thanks a lot
