Does anybody else have issue's in AC16 when 2 slabs or meshes or fills touch each other you select 1 then try to click on the outer edge to add a node or stretch etc. but you cannot select the one you want, but if you select the one next to it, it works straight away?
I've tried pressing tab etc. to see if i can select the other mesh but this does not seem to work.
