archiCAD v11 woes
howdy
we are still running archiCAD v11 on PPC and Intel mac machines running 10.6 and 10.5
the issues we are having include:
- USB key failing to be recognised at various times... we can usually load archiCAD ok.. but periodically a dialog box will pop up and inform a user that the key cannot be found)... we have swapped out the key... changed USB ports.. but the issue continues
- DWG export issues (usually crashes archiCAD whilst trying to view export options OR when trying to define a new save location)
- archiCAD crashes whilst trying to launch the attribute manager for a particular file (happens on newer apple intel machine running 10.6... older apple intel machine running 10.5 doesn't have this issue with the same file)
- shift, control, option and command keys don’t work periodically... a reboot of the machine seems to solve the issue... again.. this happens periodically on a couple of machines
- archiCAD crashing whist trying to save as a pdf from the layout book
any help greatly appreciated
thanks in advance
yukioMishma
13 Replies 13
thanks for the reply
i had already updated the JACKX
i did however upgrade to 1259... are you saying that 1210 is better/ more stable?
it would appear that some of the issues are stemming from fonts... as i have disabled a pile of fonts and some of the issues seem to have abated
thanks again
yukioMishima
Eduardo Rolon
Check on the Wiki.
http://archicadwiki.com/Bugs/DuplicateFontsCauseCrash
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
cool... thanks
