Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Forum Posts
AC 8r3v3 Crashed
I start to have problems with elevation/section because doesn't show some walls. After that AC start to crash almost every time I try to see an elevation/section. I found something in ArchiGuide about ArchiCAD Temporary Folder was very little free sp...
  • 14252 Views
  • 11 replies
  • 0 likes
keyboard shortcuts
Every once in while when using keyboard shortcuts I have repeatedly hit the button for it to finally work. For example "Drag" when hit ctrl d I find myself having to hit the d button 3 to 4 times before it picks the command up. I first thought it mig...
Red Enthusiast
  • 3802 Views
  • 1 replies
  • 0 likes
Newbie questions
I am a new user, (migrated from Architectural Desktop) and have a few questions. Any help would be appreciated. 1. How do I make the same set of stairs appear both on the upper and lower floor, but look different. (arrow down on second floor, arrow u...
Another newbie
Walls Don't Clean Up After Merge
We have had two instances where drafters have Merged a very simple AutoCAD drawing into an ArchiCAD plan and the walls will no longer clean up. I've checked the Display Options and several other things, but there seems to be no reason why none of the...
  • 10392 Views
  • 7 replies
  • 0 likes
Important Apple Message
Apple has just posted a warning message re the use of FireWire 800 HD with Panther: http://www.apple.com/macosx/firewire800specialmessage.html In short: stop using them right now before losing data. Cheers Francois
  • 4271 Views
  • 1 replies
  • 0 likes
Weird crashes- Intellimouse driven?
Anyone having crashes unexpectantly when using AC8 R3 with Microsoft Trackball mice? We have 2 workstations in the office that seem to crash when dragging, rotating, stretching paremetric objects. Or is it the NVidia GF video cards? All have latest d...
  • 8129 Views
  • 7 replies
  • 0 likes
8.1 Doors changing parameters
I'm having problems with doors changing paramenters. I have inserted door D2 from the 8.1 library and set the parameter to H-V Grid. This seems to work for a while in the 3D window (Open GL) but after a while the door has reverted back to show no gri...
  • 7340 Views
  • 5 replies
  • 0 likes
