macOS 15 Sequoia
Roman-PS
@Graphisoft:
Are there any experiences and test results about Archicad (27 + 28) is performing on macOS 15 Sequoia? (currently beta status)?
Thanks.
Regards
Roman
Operating system used: Mac Apple Silicon 15 Sequoia
Where do we go from here?
Oleksandra Vakariuk
Hi there,
At the moment, we're not aware of any critical issues in Archicad on macOS 15. However, please note that we're still in the process of testing both Archicad and BIMcloud, and there will be more OS updates until the official release, so this may change in the future.
You can find an article with the latest news about the compatibility and known issues on macOS 15 here.
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer
10 REPLIES 10
I’d be interested in knowing this too. I used to run the Betas of both Archicad and macOS to test but Apple changed the virtualisation so I couldn’t install a VM. Apparently this all changes after Sequoia so I’ll be able to test the next versions.
Lee Hankins
macOS Sequoia (15.1.1)
How will it change?
Archislave
archicad 26.0 US, M2 Macbook Air
Apple have updated their virtualisation SDK so after Sequoia you will be able to run any future macOS system within Parallels. At the moment it has to be the same os as the macOS on which Parallels is installed. You will be able to run the next major release after Sequoia within Parallels whilst still running Sequoia as your main OS.
Lee Hankins
That is Great! or I mean That is Brilliant ...
Archislave
Oleksandra Vakariuk
Hi there,
Kind regards,
Oleksandra
Oleksandra Vakariuk
Good morning everyone, following the update to macOS 15, every time I try to use Cinerender I get an error message.
I have the latest version of Archicad 27.
Am I the only one??
@Luca Ancorati,
What is the exact error message you are receiving?
Hi @Luca Ancorati,
I use macOS 15 and don't experience this issue with Cineware. Please check this article for a possible solution.
Oleksandra Vakariuk
Setup info provided by author
