visual problem archicad 24
Since i ve archicad 24 Anchor point is empty view also geometry method ,icon is working but no visual.
6 Replies 6
What is your hardware / operating system. If Windows, you may need to update your graphics driver. If Mac, then if you have upgraded to Big Sur (NOT recommended) that could be the issue...
i7 ram 32 GB cpu e5-1650v2@350ghz ,nVidia Quadro ,win 10
Miha Nahtigal
Not a problem with AC. It's a bad crack. Purchase a licence
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
Let's not assume the worst and make indirect accusations.
The problem may very well be caused by a graphics card issue as Karl suggested.
Minh Nguyen
Dear Essam,
Thank you very much for the report and I am very sorry about the issue!
I looked for a similar record, but I was unable to find it. My suggestion is to perform a Preferences Cleaning (https://helpcenter.graphisoft.com/knowledgebase/25464/). This will reset the Work Environment, and hopefully, the issue will go away afterward.
Please let me know if it helps. Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
I guess that is it , thanks a lot for reply appreciate it .
