A three leg stair
Archicad stairs library part does not provide for the three leg stair shown in the attached picture.
I try to use the custom configuration and it does not support the "path" I need
As a work around, I work out the small, 4 risers first flight; added a slab for the first landing; and a regular "U" shaped stair for the upper 2 flights.
However, I find no way to connect the railings at the first turn (corner of the first landing) and there is no way I found to omit the steps break line for the bottom first 4 risers.
Are there any suggestions you can offer to create a stair with the "path" required here.
[/img]
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
5 REPLIES 5
Bruce
Use Design > Create Stair Using Selection.
Draw your stair footprint with a fill, and your travel line.
Help is here: http://helpcenter.graphisoft.com/guides/archicad-19-int-reference-guide/elements-of-the-virtual-buil...
You may also find this interesting:
http://helpcenter.graphisoft.com/tips/how-to-create-balustrades-using-trussmaker/
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Thanks Bruce,
I was aware of the Custom way to create the stairs. However. the program is not accepting the line representing the "path". I have tried using simple segments joined, multiple segments grouped and the poly line tool to no avail.
I will try calling support and see if they can help.
Thanks for the article of using the truss tool. I have forgotten that one.
Bruce
Conrado,
I managed to get it to work ok. I've only done it very quickly, so getting the risers right may take a bit of playing around.
Make sure the fill doesn't overlap. Only select the fill and lines that define the walking path (must connect).
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
screenshots
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
3d screenshot
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
