AC25 Cabinet Objects
lparke
I'm reworking our template favorites for cabinets to incorporate new features of AC25. Perhaps I haven't found it but can you:
1) show dashed lines indicated door swings and shelving behind the doors in 2d elevations
2) at a two segment base cabinet, when I set the lower segment to a double hung door with drawers above I can't figure how to show two drawers side by side above the door panels. It only appears we can have one large drawer.
ArchiCAD v28 (since v11)
MacBook Pro M1 Max, 64GB
macOS Sequioa
30 REPLIES 30
RandyC
not sure how to make a pln small enough to send.
However the attached shows the line colors of the carcass / cabinets and contour lines
does this help ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Randy,
Thank you very much, now I was able to reproduce the issue!
Let me ask for the developers' opinion again regarding this one. It was unclear to me as well why transparent pen still shows the lines.
Once I have the answer I will let you know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Electric Flute
Hello Minh,
Could you please also send this request to the developers.
Thanks,
AC26 > AC5 - Win10
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
does this help ?
Hi Randy,
I have received the explanation from the developer: The cabinet and carcass's edges are now controlled by the MVO. If you set the level of details in 2D for the cabinet to Low, the lines will disappear. But with low level of details, the sinks and taps will also be simplified/removed from the 2D plan. The only workaround is to use the same pen for the cabinet/carcass's edges and use a solid fill for the counter if you need to hide the edges.
I talked with the designer and we do see that this is a massive setback from user experience and functionality point of view. Therefore, I have enter the issue as defect DEF-5951. Fixing this would require an update to the whole cabinet objects, so I cannot promise a fix in the near future. Rest assured that I will do my best to ask for fixing these in the nearest possible timeframe.
I truly apologize for the inconvenience that you are having with this defect. Please let me know if you have any further questions. Thank you very for your understanding!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Electric wrote:
Hello Minh,
Thanks,
Thank you very much for the report!
After some testing, I believe this was intentional (if you see the front panel options in Archicad 24, they only have 2 types of joints, but the joints were not visible in sections/elevations). However, I believe that we should have an option to hide the joints in sections/elevations, as the architectural drawings often do not include this. I have entered a request for our developers (please refer to it as DEF-5955) to implementing something similar for the new cabinet system.
Thank you once again for sharing the issue. I wish you a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Hi Minh,
Rather than putting the carcase and cabinet line parameters back in the object, would it be possilble (easier even) to add those to cabinet parameters in the MVO configuration? That way we could hide the lines in some views and show them in others based on MVO.
cheers,
-Bryan
MacBook Pro 13" - 2019
2.8GHz quad-core i7 w/ 16GB
AC21-25
Adding to the issues.
There is no ability to control edge visibility in 2D plan for units that don't have a counter.  So you cant display three adjoining wall units as a rectangle which you quite often want to do at low LoD.
Roy Cassim
Can I please confirm, as per the original post, is there a way of showing the cabinet carcass/ shelves and door swings in elevation?  This is separate from the discussion of the level of detail and lines shown in plan. MVO have has been set to full, however the carcass or door swings still don't seem to be showing in elevation.
AC 27 | Melbourne-Brisbane | Est. Since AC 6.5 | WIN 10 Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz |
Hi, is it something new in this Topic ? Can I design invisible line ?
I'd like to get rid of lines this 2 lines under a Keep sink to be visible.
MVO - It's not helping in this case because how was said this hiding sink.
Skärmavbild 2022-01-10 kl. 16.24.50.jpgSkärmavbild 2022-01-10 kl. 16.24.43.jpgSkärmavbild 2022-01-10 kl. 16.25.42.jpg
AC 7 - 27 SWE
MacBook Pro, M4 Pro
I'm going to echo this request. The lines that define the edge of the sink should really disappear (especially in the undermount sink). The sink in 2D doesn't look undermounted with them there and my boss is not happy about that. For now I'm having to use a white fill to cover them. I also tried using the Cabinet with Sink object as it's 2D sink looks correct. The problem is, however, that I can't get rid of the top of the base cabinet. If I turn off the counter, it's a solid top to the base which then conflicts with my sink. Not great.
AC 27
MacBook Pro:: M3 Max / 128GB RAM
PC: 12th Gen i9 / 64GB DDR5 RAM / RTX 4090
