a week ago - last edited 6 hours ago by Laszlo Nagy
Does anyone know how to set up the door frame so the texture aligns correctly as shown here?
The goal is for the vertical parts of the door frame to have a vertical texture and the horizontal parts to have a horizontal texture.
Operating system used: Windows 11 Pro 23H2
a week ago
Other than scripting or creating (Library Part Maker) your own objects, I don't believe it is possible.
a week ago
Ok, no worries, is just for one rendering, I ll change it at the end in photoshop.
Thank you!
a week ago
In the dutch library the texture is standard correct oriented
You can also set a mitered connection:
This is in AC27
Thursday
I just checked a door frame in 28 and it is the same as you show in 27 with each part of the frame having the material run along it.
And you can control the corner joint as well.
Maybe the version 26 library objects that @ananas is using do not work this way.
Thursday
They actually updated this? Did they fix the door panel texture orientation?
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
Thursday
Looks like it.
