ArchiCAD25 Door Leaf Undercut: Parameter not available?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-01-24
08:28 PM
‎2023-05-24
09:40 AM
Rubia Torres
The leaf undercut parameter seems to not be visible for any door - I have been searching through the "Tool Setting Dialog Boxes" thinking that maybe this parameter was hidden by default - but I have turned them all on to "visible" and I still don't see the parameter available in any of the doors
I am beginning to wonder if GS moved this parameter elsewhere or removed it? I am fairly new to ArchiCAD and have only seen posts related to the door undercut from 2+ years ago
Windows 11
16 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-24 08:46 PM
It's available for hinged and rotating doors via the door settings and opening tab then frame and leaf dialoug window:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-24 08:56 PM
Maybe it is something that was done in the creation of our companies template/libraries/work environments? I attached a screenshot - this is a hinged door but is not classified or titled so in the Library
Windows 11
16 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-24 09:06 PM
I also just downloaded these doors from the global library, still having the same problem even though these are actually classified as hinged doors
I appreciate your time!
Windows 11
16 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-24 10:07 PM
You are welcome,
which Local version you use? I think it’s not the INT one, the library maybe different.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-25 08:18 AM
I use the UKI version and I don’t believe that has the setting for undercuts on the door leafs. It is something that would be very useful though.
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-25 03:02 PM
I believe its the USA version as that's where I am located. Is there anyway we could get an answer from an Admin about why some libraries do not come equipped with the leaf undercut paramter? Seems strange...
Windows 11
16 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-25 05:44 PM
@Laszlo Nagy I have seen you provide some helpful insight on other posts - anything for this?
Windows 11
16 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-01-25 06:46 PM
Also @Eduardo Rolon is using US version, I hope he can help you in this issue, I'm sorry I can't help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-03-26 10:16 PM - edited ‎2023-03-26 10:21 PM
Sometimes I use this to get the correct rough opening to show up on in the schedules and keep the door relative to the sub floor, rather than finish floor. For me, the subfloor is always at a Story level rather than at the finished floor where the bottom of the casing is. We don't actually have settings that are very useful to me. A lot of people use doors other than what is default in the provided libraries.
