Aaron wrote:
If I understand the MEP documentation correctly, the plumbing parts lose their MEP 'smarts', lock themselves down so that they must be unlocked to be edited.
They regain their smarts once opened with an MEP enabled ArchiCAD.
That's correct, Aaron. Good to point that out.
But, lest it sound scary to anyone - the 'smarts' are not truly 'lost', but are simply not active, and the 'lock' is just the ordinary AC lock/unlock, so easy to either unlock everything from the Edit menu, or just a particular object from its context menu.
Yes, when opened again with an AC with the MEP add-on installed and licensed, if the hotspots of MEP-enabled parts are adjacent to one another, then the pieces are once again recognized as a system.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
