2014-09-05
		09:40 PM
		2023-05-24
		10:50 AM
			Rubia Torres
2014-09-05 09:49 PM
2014-09-05 11:23 PM
2014-09-06 04:42 AM
2014-09-06 06:30 AM
Erich wrote:In addition - command TUBE as opposed to PRISM_ - hollow, that you will have a sectional? Empty. Only the section of contour.
In 3D cut your wall opening to the larger dimension and infill the triangular areas with a PRISM_ or EXTRUDE part. The TUBE command does not look good in 3D or renders (at least in the past, I have not check with 17 or 18 yet) so I try to avoid it when possible. ....
