vs93_11
Can't import 3ds into archicad 28
I have problems while importing 3ds model into Archicad  28, in Archive > Interoperability > there's no "import 3ds..."
I already installed Goodies Library
I already checked into Add Ons Menù, and 3D studio import is flagged
I already moved into "Menù"
In your opinion, which is the problem? What can I do?
Thank you all in advance
Setup info provided by author
13 Replies 13
According to your Work Environment, it is in the Opzioni > Barra Menu and not Archive > Interoperability.
Lingwisyer
Guru
You can always just select it in the Add-on Manager and it will tell you where it is in your interface.
Ling.
vs93_11
Thanks for your feedback Berry,
but the problems is exactly that I can't see this option.
vs93_11
Yes and the Add On library is already charged on archicad, but still I can't see it.
i don't undestand the reason why.
cuba
It is not under file/interoperability but under design/designextras...
Apple M1 Max 32 GB
Latest AC
And, if you cannot find the commands anywhere in the menu, you can add them manually in the Work Environment Dialog.
dushrene20
The option is no longer under interpolability. You can now find it under Design>Design Extras>3D Studio
Patrick M
Ace
yeah, definitely gotta be a w/e issue...
@Laszlo Nagy  ; wasnt this one of the add-ons or goodies that was integrated recently? maybe he's using a migrated work environment that didn't include the feature?
Lingwisyer
Guru
That might be a change in your regional template / installation. AUS and INT both default to the interoperability menu.
