Can't import 3ds into archicad 28
vs93_11
I have problems while importing 3ds model into Archicad  28, in Archive > Interoperability > there's no "import 3ds..."
I already installed Goodies Library
I already checked into Add Ons Menù, and 3D studio import is flagged
I already moved into "Menù"
In your opinion, which is the problem? What can I do?
Thank you all in advance
6 REPLIES 6
According to your Work Environment, it is in the Opzioni > Barra Menu and not Archive > Interoperability.
Lingwisyer
Guru
You can always just select it in the Add-on Manager and it will tell you where it is in your interface.
Ling.
Thanks for your feedback Berry,
but the problems is exactly that I can't see this option.
Yes and the Add On library is already charged on archicad, but still I can't see it.
i don't undestand the reason why.
cuba
It is not under file/interoperability but under design/designextras...
Apple M1 Max 32 GB Ventura
AC27
And, if you cannot find the commands anywhere in the menu, you can add them manually in the Work Environment Dialog.
Setup info provided by author
