I'm going to talk about working with reinforcement drawings.
You need to take a part from the floor plan and place the reinforcing bars.
The floor plans partially imported from archicad are converted to 2D. Can 3D reinforcement be placed on them?
Will it be reflected in other plans, elevations and sections?
(In Revit, you can cover the rest with a crop view on the plane. : The problem is that only dimensions and labels are available outside the crop view, so there is a problem with the work... ^^)
AC27 on window 11
