ā2021-05-19
09:44 PM
ā2023-05-24
10:39 AM
Rubia Torres
ā2021-05-20 03:20 AM
ā2021-05-20 03:23 AM
dhnguyen wrote:
Does this have anything to do with keeping the file in "legacy format" when I moved the file over?
ā2021-05-20 04:11 PM
Lingwisyer wrote:
Just to clarify, you open a AC18 file in AC24, place a new door, and are unable to change it's size?
Door 24 in version 24 in an 18 file.
Ling.
ā2021-05-20 04:13 PM
Barry wrote:
I shouldn't think so, but the only way to know for sure is to turn the legacy mode off.
You can always turn it back on again.
Is the wall layer locked by any chance?
Is the OK button in the door settings greyed out or will it just not accept a new size?
ā2021-05-20 04:32 PM
ā2021-05-21 03:09 AM
ā2021-05-21 03:08 PM
ā2021-05-21 07:30 PM
ā2021-05-22 02:08 PM
dhnguyen wrote:The author of the library part should have locked the A and B values when the door is set to a standard size (anything but Custom Size) to help avoid confusion.
So weird that I have to manually do it this way instead of having the ability to change it without going into the door settings.
