2004-01-15 01:48 AM
2004-01-15 01:57 AM
Miquel wrote:
I want to change the attributes (pen color, styles,etc.) of the original Archicad Library parts to adapt it at our drawing standards and not to have to change it manually every time, but I don't know how to do it to guarantee futures upgrades of librarys (and don't repeat the work every time). I have changed some of the 8.0 objects as a trial and I have lost my changes with the 8.1 Library.
How can I do that?
My first idea was to duplicate these objects with another name in a custom library, but it seems idiot to duplicate objects only for this reason and it will not solve the problem of the upgrade.
2004-01-15 10:30 AM
david wrote:I don't want to change code, only the pen numbers (and others parameters like styles of doors/windows) by default. Its easy to do, like you say, but if I do this work for a great number of objects I guess that I will need to redo it with the next Library upgrade. My question is how to maintain my changes (that does'nt affect code) and to be able to upgrade the library with new features in the future.
If they are parametric, you will never have to change them in the code
. if you want them to have certain pen numbers by default, open the object, set the colour of pen etc, then save the object.
make sure you have ticked the box for 'use objects own pens' etc etc.
2004-01-15 02:52 PM
Miquel wrote:No way.
Miquel wrote:You're not missing a thing. To the contrary, you have nicely articulated the virtual building ideal. That quote should be the professional oath of object writers. It is the AC libraries and, especially, library management that are missing a lot.
...I prefer that everybody is concentred on the desing, leaving the representation issues as automatic as possible, and not to have to change every attribute of every object.
Or I am missing something ?
2004-01-15 06:55 PM
2004-01-20 04:04 AM
Miquel wrote:I have the same question. It amazes me that there is no way to globally change the basic parameters of objects like doors and windows. Must I really go through each and every object to set pens, trim sizes, etc . . .?
Favourites are pretty good, but not for 26 doors, 18 windows, 86 objects etc. (for example) I know that every user can change all the settings, but I prefer that everybody is concentred on the desing, leaving the representation issues as automatic as possible, and not to have to change every attribute of every object.
2014-04-13 06:38 AM
2014-04-13 03:38 PM
2014-04-13 07:33 PM
GDL Technical Standards contains GRAPHISOFT’s official standards for professional library developers; this information is part of ArchiCAD’s Basic Library documentation, and can be downloaded as part of the LibDev Toolkit from GRAPHISOFT’s website after registration:
http://www.graphisoft.com/support/developer/.
2014-04-14 03:59 AM
