2015-09-03 10:46 PM
2015-09-04 01:36 PM
2015-09-04 03:38 PM
2015-09-04 03:46 PM
2015-09-04 04:08 PM
Tom wrote:oh its already happening. just have to rewrite the stairs one more time to have them work the way i want. if you cant get the stairs to work then pm me and ill let you test the stair, ill even add the walking line for you.
Will try it with the chained line. Never have had a reason to use it.
Also read in the help menu that the location of the angle in the walking line will create a landing. Am going to try to change the line layout.
Although that stair layout you generated will work....have to check the dimensions of the treads at the winders to make sure they meet
code.
Seneca....you can make a million dollars if you get that stair and railing maker to work together.
Tom
2015-09-04 04:32 PM
