ā2021-02-03
01:28 PM
ā2023-05-24
12:24 PM
Rubia Torres
ā2021-02-03 02:39 PM
ā2021-02-03 02:54 PM
ā2021-02-03 11:17 PM
Erwin wrote:I didn't find a marker that can do what I asked. As suggested by Fra, I can use label to add ID and some other information only in 1:50 views, but I see this as workaround, because I need to add new elements and a dedicated layer. And didn't find a way to hold only hole axis in 1:200 scale.
I think one of the markers that ships with AC allows for scale sensitive settings.
Erwin wrote:I did many GDL objects in past times, but with the latest Archicad version, GDL has become too complex and I have to less time.
In the end it's just a GDL scripted library part, so it can be altered to act whichever way you like, but if you are unfamiliar with GDL this might be a lot of work.
ā2021-02-04 10:06 AM
ā2021-02-04 10:51 AM
ā2021-02-06 06:00 PM
Fra wrote:How did you obtain this? Editing marker settings? The problem is to obtain only axis in 1:200 views, axis with dimensions in 1:100 views, and a complete marker with axis, dimension, ID and still hight in 1:50 views. Mostly I can bundle the kind of marker to the scale, but I think it can be handled even better with MVO
Borgo1971
it seems to me possible to have only the axis of the hole
ā2021-02-09 06:53 AM
ā2021-02-11 12:21 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
