2012-03-23
04:16 PM
2023-05-24
10:53 AM
Rubia Torres
2012-03-23 04:17 PM
2012-03-23 06:44 PM
2012-03-23 07:01 PM
2012-03-23 07:37 PM
2012-03-26 03:15 AM
Rick wrote:I like that fridge analogy - hadn't heard that one before.
Note: In Australia, this is different. The refrigerator rule applies (you can't stand in a fridge, the door always opens towards you) - If the hinges are on the left then its a left hand (or left hung) door. If the hinges are on the right then its a right hand (or right hung)
2012-03-26 03:46 AM
2012-03-26 11:05 AM
Rick wrote:We always worked to door hardware manufacturer's guidelines, which was always from the exterior/public/outer side (for security purposes) but the handing was the side the latch/lockset was fitted to - see an example here. Thus doors were designated LHOO (left-hand-open-out), LHOI, RHOO, or RHOI. In some cases, the specification and detailing of each instance is unique.
US = Right hand hinge (RHH): Standing outside (or on the less secure side (i.e., standing on the side you use the key on, going from outside to inside, or from public to private)), the hinges are on the right and the door opens in (away from you).
2012-03-26 03:50 PM
2012-03-27 05:03 AM
