2012-08-28 04:13 PM
2012-08-29 12:16 PM
2012-08-29 01:01 PM
2012-08-30 02:06 AM
2012-08-30 01:21 PM
giuseppe wrote:The element ID, like other element parameters, is a default value. So the ID should be set before using the tool. Changing the ID in the template, like changing other default values, will make this easier to use.
but my question was why the name is always the same, and if I want to scheduled them using the ID................ all will be scheduled or not.
Thanks any way may be the problem is in our template file we use.
2012-08-31 02:29 AM
