2007-02-19 01:04 PM
2007-02-20 04:42 AM
sakshi wrote:You should be able to load libraries from both. However you will notice significant slow downs if you load them from the network and may even time out if your server is really slow or has alot of traffic. It is better to put your libraries on a local drive and use something like Allway Sync (for PC) to update the libraries to everyone on your network. There are lots of other programs around that do the same thing, depending on what platform you are using.
I am facing lots of problems while loading a library. I have tried for loading the Library from the Local and Network.
Can anybody give me any idea on whether the ArchiCAD Default Libraries and other Company Libraries should be put on Local Drive or on the Network Drives?
2007-02-20 04:49 AM
sakshi wrote:Actaully i only just looked at your screenshot closer after posting the previous message. Still follow the advice to put your libraries on a local drive but to your exact problem...
2007-02-20 08:10 AM
2007-02-20 02:46 PM
2007-02-20 11:13 PM
sakshi wrote:I wouldnt think so, It is most likely that the problem lies around you loading libraries with 6000 errors. Better to check this throughly before looking at hardware problems.
Mark,
Thanks for the early reply. I shall try out the way you told me.
The following website suggests about the system requirements for ArchiCAD, which mentions that the UNIX formatted HDs are not supported.
http://www.graphisoft.com/support/archicad/system_requirements/
Actually we are using the Linux based server (UNIX Formatted) for storing our file, libraries etc.Does that affect the running of the software?or Loading of the Libraries?
