JLopes
Favorite Converter Tool - AC28
I'm having problems with the tool to convert favorites, is there any tutorial?
Since the link in question is not directed!!!!
|| JLopes ||
AC29 Port || Ryzen 9 5900x | RTX3080 | Win
24 Replies 24
scottjm
Mentor
What does the last few lines in the conversion log.txt show?
Funfun Yan
WOW,where can I download this tool! I have to convert my favorite too!!
THX!
According to the AC28 New Features FAQ, you have to write mmarosvari@graphisoft.com. They also say that a more user friendly version will be published around the AC28 release. I haven't found anything yet though.
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Funfun Yan
Thank you very much Bernd!😁
Magdolna Marosvari
Hi @BerndSchwarzenbacher ,
The screenshot @JLopes showed is already about the user friendly version, that can be downloaded from here:
https://graphisoft.com/resources-and-support/downloads?section=favorite-converter
I'll update the link, also the FAQ, and the tutorial video can be expected around 17th October.
Regards,
Magdolna
Funfun Yan
I converted them, but can't import them in 28.   it shows this.
and the convertion is I think success.
Magdolna Marosvari
Hi @Funfun Yan ,
Please take a look at the attached manual to see the recommended workflow.
Let us know if it helped.
Best regards,
Magdolna
Funfun Yan
Hi Magdolna, Thank you for your manual, it works! And I found the key is we need to use ac 28 to export AND import. The reason I failed was to use ac 27 open the file and export , then used ac 28 to import.
(ps: There will be many favorites that will not trans correctly which will need to rebuild manually.)
Thank you again. Have a good day!😀
Patrick_lgs
It doesn't work for the POR (portuguese) version
Regards,
Magdolna
