ā2007-03-05 03:36 PM
ā2007-03-05 06:43 PM
ā2007-04-01 08:34 PM
ā2007-04-03 08:23 PM
ā2007-04-03 10:14 PM
Check also selfgdl, the selfless effort of the local German GDL gurus.
ā2007-04-11 04:15 PM
ā2007-04-12 10:55 AM
ā2007-04-12 01:07 PM
ā2007-04-12 04:31 PM
prashant.gholap wrote:If they are all in the same file it will be fairly easy. Just set up a Publisher set, drag and drop the views, and adjust the settings as needed. If they are in multiple files you will need to repeat this process in each file. OR... You might be able to link all the views into one master file and publish all in one go. This should work but I am not sure it would be any easier.
I am having 350+ details files in pln format, Can I batch print this details in pdf format with publisher in one go?
I have gone publisher documentation as per my understanding we can publish document which are already present in Archicad project.
