‎2004-04-27 02:15 PM
‎2004-04-27 07:53 PM
chris_pap wrote:Import it as any 3D DWG.
Dear People
I have created a 3D block in AutoCAD that I would like to import in ArchiCAD and use it as railings pattern in most of my projects.It is shown in the attachment.How can I import it in ArchiCAD?I must say that the use of this specific railing is the only reason for me returnig to AutoCAD from now and then.
Please help.
‎2004-04-28 12:05 AM
‎2004-04-28 01:10 AM
chris_pap wrote:No, what you're trying to do is correct. Merge/xref only brings in 2D information ... to get 3D you have to open the DWG/DXF as an object...use the forum Search function to find other discussions about this.
Do you mean that I should merge the drawing?Will that method keep the 3D properties of the block?
What I am trying to do is "Import Block from DWG/DXF" through the GDL Objects menu.
‎2004-04-28 11:48 AM
‎2004-04-28 11:49 AM
‎2004-04-29 01:18 PM
chris_pap wrote:Yes.
And here it is the way it looks when imported.Here it is shown in wireframe mode.In rendering projection the extra lines do not show.
But if I perform an elevation these lines within the steel frame appear.
Any suggestions please?
‎2004-04-29 08:01 PM
‎2004-04-29 09:13 PM
