‎2023-05-02 11:35 AM
Good morning,
I have tried making holes on complex profile (simple bolt holes on a steel plate) and it does not seem possible to decide the axis with respect to which the hole will be placed: as if the beams can be drilled only perpendicular to their body and Z axis. Am I a beginner or is this a boundary of archicad? (Acad18 workspace)
Thanks to those who can answer me.
‎2023-05-02 12:09 PM
Use beams when doing your complex profile it will allow you to create holes in that element. Hope it helps you.
‎2023-05-02 01:08 PM
Yes, it works only on beams and walls and (exactly my question) only on one spacial axe. I suppose this is rather a tool to plan technical passages through beams rather than bolt holes...
‎2023-05-02 01:09 PM
Thank you for the answer!
