Hotspot 2
I have some element and on these I will use macro.
When I use the macro I get problem with hotspot2 now I call them.
I can not stretch them now I'm changing dimensions; with (call macro_navn parameter B = 0.900, etc, etc, ..)
See picture in which I explain it a little more.
Someone I an idea of how I solve this
Thank you in advance
Laurits
If You wish the hotspots in the macro to work You need to have exactly the same parameters names that utilize the hotspots in caller object and the called macro.
Another thing is the hotspot id which have to increase with every hotspot.
Best Regards,
Piotr
Hi
Is there anyone who can explain it to use unique ID on hotspot2 when using them in a Macro.
As a novice realize that I'm completely blank on this with ID. I Google it many times but find no good answer for it.
Please help me
