‎2025-07-06 09:59 AM
A friend sent me some AI-generated 3D furniture models in the *.glb format. How can I use them in Archicad? Thank you!
Operating system used: Windows 6010
Solved! Go to Solution.
4 weeks ago
If you are a little bit familiar with GDL, it is very easy to add a simple and detailed toggle parameter where you could substitute the detailed model with something less detailed and swap in the detailed model for artist impressions only.
3 weeks ago
There is no direct import of .glb into archicad.
Convert it into .3ds file with something like https://fabconvert.com/convert/glb (add-on goodies 3dstudio in: https://www.graphisoft.com/us/downloads/goodies)
3 weeks ago
You could check if the FBX files was properly exported from Blender. There are a lot of free online FBX Viewers on the net. You could try viewing the FBX file in them:
