How to remove the frame around trees?
AEP - Jochen Eggert
Does anyone know, how to get rid off that frame of the trees in 3D?
Thanks.
 [Topic title edited by moderator to be more descriptive. Original title "Trees - ..it's urgent!"]
AC 4.55 -
8 REPLIES 8
runxel
Hero
Hey there, first of all, you're posting in the German Forum (maybe @Claudius can move this topic!), secondly: You can use a GO since AC 25 for that (hiding contour lines).
vistasp
You may already know this, but the outline will not show in the rendering, provided you use one of the Physical renderers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Hmooslechner
A veeery good question.. No - You cant get rid of it as far as i know.
thumb Workaround:  Make a new penparameter in the GDL - and give it a light colored pen - then insert this in the 3D-Script (nearly on its end) on this place and save it on a new name - to get a librarypart of You own - without altering the original. Then insert this new librarypart and play with it...
material "TreeMat3D"
!!!! Here You insert:
Pen YourPenName
!!!!  End of Your insert
vert	EPS, 0, EPS					! 1
vert	A-EPS, 0, EPS				! 2
vert	A-EPS, 0, _PicSize-2*EPS	! 3
vert	EPS, 0, _PicSize-2*EPS		! 4
edge 1, 2, 0, 0, 0
edge 2, 3, 0, 0, 0
edge 3, 4, 0, 0, 0
edge 4, 1, 0, 0, 0
pgon{2} 4, 0, 0, 6,
	-EPS, 0, 0,
	1, 0, 0,
	-EPS, 0, 1,
	-EPS, 1, 0,
	1, 2, 3, 4
body 1
del nTrans
end
Yves
I think if we want to modify the script 3D of the object then I will do like this
!!!!Old script
!!! edge 1, 2, 0, 0, 0
!!! edge 2, 3, 0, 0, 0
!!! edge 3, 4, 0, 0, 0
!!! edge 4, 1, 0, 0, 0
!!!!New script
edge 1, 2, 0, 0, 1
edge 2, 3, 0, 0, 1
edge 3, 4, 0, 0, 1
edge 4, 1, 0, 0, 1
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Thats it! Easy!
You could, of course, give it an new parametername to switch it on/off it from the user-interface.
Thank You!
Steve Jepson
Trun off "Show Contours" in 3D Styles.
Thanks for the numerous answers... have now created an override technique for this tree, and displayed the "contour lines" here!
AC 4.55 -
The trees "outline" contour lines are on Pen 4. So - although not ideal - you can retain the contours on the building and reduce the impact of the tree dark rectangle by changing Pen 4 to White or Light Grey.
