Lasse
Jung product library issues
Hello! Does anyone know how to rotate the 2d symbols in Jung product library or is it just the way Jung intended? They are pointing the wrong way - towards the wall/switch. Mirroring does not work, no extra option in the custom settings.
https://www.jung-group.com/en-DE/Service/Downloads/BIM/#archicad
Thank you
4 Replies 4
It looks deliberate to me.
Do either of these hotspots rotate?
If not, then as it is a 3rd party object, you would have to contact the creator.
Erwin Edel
I would disconnect the symbol from the 3D element, but that's because generally the symbol is larger than the outlet / switch etc, so getting a readable floorplan output becomes very tricky.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Ricardo Lopez
Hi @Lasse
It is complicated to modify the symbol part rotation because the object library is not editable in the GDL editor.
Anyway, even it is a manual workflow, you could turn the symbol off in 2D/3D SETTINGs> 2D Appearence and draw/place your own rotated symbol.
Ricardo López, M. Arch.
Botonis
Mentor
Forget about Jung and buy this library:
https://gdlfragments.com/object/electroblock-1-7/
from Evgeny.
The most optimized electrical library ever for serious electrical documentation and 3d representation.
