MORPH object Base Point Manipulation?
Jeff Galbraith
Is it possible to specify the base point of a morph or a custom object? When I create a morph archicad chooses a node to be the morphs point of origin, using it for the basis of placement and measurement such as elevation above there overall model origin etc. It's typically located at the corner of an object drawn in plan, which is most often not where I want it. Is it possible to customize the location of this node?
Jeff G
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
0 REPLIES 0
