New curtain wall spider object
Ahmed_K
Mentor
Hi GDL masters !!
I made this CW junction using archicad tools ( slab , shell ... ) it can be used as GDL object but not parametric ( different glass thicknesses or distance between the glass and the structure profile )
all components are separated , , can someone use all the components as macros to make custom GDL object ( parametric ) to replace the existing CW spider
here is the file AC 18
any suggestions are welcome
here is the archicad file :
http://www.mediafire.com/download/c35b2r146s2br1n/2+legs+CW+junction.rar
Archicad 27
Windows 11 professional
5 REPLIES 5
Ahmed_K
Mentor
articulation ossibilities
Archicad 27
Ahmed_K
Mentor
junction posibilities
Archicad 27
Ahmed_K
Mentor
Any propositions please !!
Archicad 27
This would not be to hard to accomplish. But it would take some time to make it parametric. I started learning gsl this year, the gdl PDF has everything you need.
Ahmed_K
Mentor
i will try to learn gdl too it's useless to use archciad without some gdl knowledge
graphisoft does not offer any master level tutorials , just some basics šŸ˜•
anyway i hopo i can script it one day
Archicad 27
