Object 2D view loses hidden edges effect
Dalius
When I save fills or slabs as an object, I get a different 2D view. Object that was made from fills looks OK, however object that was made using slabs loses hidden edges effect. Is it a bug? Does somebody know how to fix it?
Dalius Regelskis
Archicad user since version 6.0
https://archicad-pamokos.lt
11 REPLIES 11
Frank Beister
No. Drawindex does not work, because you can only toggle between (all!) lines visible or lines invisible (coverd by the fills). Only if you have less than 8 fills it could work, because DRAWINDEX is limitated to 8 "groups".
AND, why is it not exported the right way?
Dalius
There are 3745 poly2 commands in my object 2D script... Is there an easier way to get a true floor plan view?
Dalius Regelskis
