‎2017-01-06 04:41 PM
‎2017-01-06 04:53 PM
‎2017-01-06 05:02 PM
‎2017-01-06 05:20 PM
‎2017-01-06 07:58 PM
alemanda wrote:I have done this many years ago where I had to sum up the areas of multiple Zones that belong to the same apartment. Zones belonging to the same apartment were given the same Element ID. Then each Zone would use the GDL Data Extension to write its area value into a file with the same name as their common Element ID (for example, "A-13", and A-13.txt). Then these Zones could also read back the sum of areas from the same file.
You can write/read the total number in/from a text file.
