2005-08-31 08:22 PM
2005-08-31 08:44 PM
2005-08-31 08:46 PM
Link wrote:I KNEW I had seen that somewhere....
Being somewhat of a GDL dunce, I don't dabble in this forum too much, but I do know that it is possible to give an RGB color to a fill in PlotMaker.
2005-09-01 08:41 AM
2005-09-02 01:43 PM
2005-09-02 03:37 PM
F. wrote:Close... PROJECT2 3, 270, 3 seems to work, if I create an inline MATERIAL definition, with Red, Green, and Blue parameters... no way to get a color picker that I can find.,,
AFAIK there is no way in AC to use any other than the 256 colors of the pen set. There are a few REQUEST and REQ functions to "ask" for the best fitting PEN to a color RGB-value, but it returns given colors and does not define them.
The only way to use gdl defined colors is to define custom materials. Bernhard Binder wrote in 2002 an object wich had a smooth color changing by using this technic. But if you use project2 3,270,2 I think AC will try to use only pens of the set. No way to trick.
2006-07-14 09:15 PM
Link wrote:Aha! What about pen -2!
I have wished to GS that they allow us a similar functionality in ArchiCAD - no news yet!
2006-07-15 06:46 AM
2006-07-15 12:38 PM
Link wrote:Hm, why did my search turn up this old thread and miss that one? Not trying to trip you up anyway. I must have remembered you mentioning it, and I just dropped it in the first place I saw.
Quoting me from over a year ago there mate! When RGBwasonly available in PM. There was a discussion on RGB colors and pen -2 more recently.
I first stumbled across it when copying a pasting the new shaded elevations onto the floor plan..<slaps forehead> Of course you'd need them for that. The old 3D window polygon method of rounding to the nearest pen wouldn't cut it in a Drawing SE.
..I just wish we could adjust the RGB values!That's the thing, the tech is in there, why can't we use it? Are they afraid we'll break it? It's strange to wish for something that AC already has.
2006-07-16 04:42 AM
<slaps forehead>Don't beat yourself up there James. As usual I am in agreeance.
