2023-01-11
05:33 PM
2023-06-07
02:46 AM
Gordana Radonic
We use interior swing doors with transom a lot in our office and occasionally need an interior pocket door with a transom object. It seems like Archicad does not have this option? Is there a way I can add this perimeter into the pocket door object? We have been just placing the int. pocket door without and then adding a separate transom window object above but would prefer if this was all just one object.
2023-01-12 02:17 AM - edited 2023-01-12 02:27 AM
Open the relevant door object and toggle gs_door_transom, then save it to your desired library with a new name. As far as I know, this can be done with all of the default GS doors.
Ling.
2023-01-12 03:26 PM
Thank you for this is it helpful. When I went into the object master I did not see what you have sent an image of. I then went into the parameters tab and tried to turn on the transom option in there and it would not let me click it. Any ideas what I might be missing?
2023-01-13 02:01 AM
Given the display units, do you happen to use the US library? That might be the cause for the difference. Please add a signature to your profile with the relevant information as stated on the link in mine. So what is in the Master script?
2023-01-13 03:58 PM
I am using the US library. Ill attach images of everything that is listed in my Master script.
2023-01-16 02:12 AM
Yeah... US library things... Might you be able to make do with downloading the INT door from BIM Components? This can be done through the door tools search bar. "Pocket Door [version]"
