‎2018-10-04
11:41 AM
‎2022-09-23
02:26 PM
Oleksandra Vakariuk
PROJECT2{4} 5, 90, !projection_code, angle,
0, 1+2, !useTransparency, statusParts,
1, !numCutplanes,
b/2 + gs_fw_lower - gs_fw_upper, !cutplaneHeight1, ..., cutplaneHeightn,
2, 1+2+4+8+64, !method1, parts1,
gs_fill_type, !cutFillIndex1,
gs_fill_pen, gs_back_pen, !cutFillFgPen1, cutFillBgPen1,
0, 0, 0, !cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1,
gs_cut_pen, 1, !cutLinePen1, cutLineType1,
65, !projectedFillIndex1,
19, 19, !projectedFillFgPen1, projectedFillBgPen1,
0, 0, 0, !projectedFillOrigoX1, projectedFillOrigoY1, projectedFillDirection1,
gs_pen_2D, 1, !projectedLinePen1, projectedLineType1
gs_cut_pen, 4, !cutLinePen1, cutLineType1,
gs_pen_2D, 4 !projectedLinePen1, projectedLineType1
‎2018-10-15 09:20 AM
Those lines are drawn manually in 2D. Project2 does not seem to show the edges of the Wallhole. I have manage to get a workable display of the Wallhole edges using a set of Planes to case the hole. They also allow me to set the material of the Wallhole. The down side of this is that these planes conflict with the wall itself in 3D...
fill gs_fill_type
pen gs_cut_pen
Project2{3} 5, 90, 3+32+4096, 1+2+8,
gs_back_pen,
0, 0, 0
‎2018-10-15 09:49 AM
‎2018-10-15 11:50 AM
IF GLOB_CONTEXT = 2 THEN !Plan view SECT_FILL gs_fill_type, gs_fill_pen, gs_back_pen, gs_pen_2d CUTPLANE 0, (gs_fw_lower + gs_int_fw + 2*gs_louvre_width) If abs(gs_louvre_opening_angle) > 0 then If abs(gs_louvre_opening_angle) < 90 then gs_louvre_opening_angle = 45 endIf endIf If LouvreOri = "Horizontal" then Louvre_over = 0 endIf ENDIF
‎2018-10-16 03:09 AM
‎2018-10-16 04:02 AM
‎2018-10-16 04:37 AM
IF GLOB_VIEW_TYPE = 2 THEN
!IF GLOB_CONTEXT = 2 THEN !!this one works as well but is deprecated
!if bUseCutPlane then !!comment out the manual cutplane option
addz A/10
cutplane{2} 60, bUseSameSurface
del 1
!endif !!comment out the manual cutplane option
endif
‎2018-10-29 09:39 AM
‎2018-10-29 10:03 AM
‎2018-10-29 10:17 AM
‎2018-12-06 09:30 AM
