Sink - can't delete or alter
KeesW
AC24 won't allow me to delete, or alter, this sink. Also, the bottom R button is greyed out and y changes made to the sink cannot be saved and used. Why?
https://archicad-talk.graphisoft.com/download/file.php?mode=view&id=42913
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
4 REPLIES 4
That looks like a Cadimage sink.
I don't use Cadimage objects, but I believe you may need a subscription license to use their parts.
Otherwise you can see them but not adjust them.
Lingwisyer
Guru
Given the grey corner nodes, I would say that your layer is locked.
Barry wrote:
Cadimage sink.
CI Essentials Sink, so it's part of the AU/NZ subscription.
Ling.
Barry wrote:
Cadimage sink.
Ling.
Yes that would be it.
I just loaded the CI Essentials library and the sink works fine - unless it or the layer is locked.
Erwin Edel
You could also have accidentally locked the object itself.
Edit > Locking
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
