rob2218
Transom material change? where?
see attached
basically have touched just about ALL the toggle buttons, radio buttons, pull-down arrows..etc...of this object and cant' see where I can change the 'surface' of the frame around the transom ONLY to a different material (in essence a different color)?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
10 Replies 10
rob2218
amazing Edurado!...that solved the issue.
simply amazing...
thank you thank you thank you so much sir!!!!!!
i>u
Edgewater, FL!
SOFTWARE VERSION:
