Transom material change? where?
rob2218
see attached
basically have touched just about ALL the toggle buttons, radio buttons, pull-down arrows..etc...of this object and cant' see where I can change the 'surface' of the frame around the transom ONLY to a different material (in essence a different color)?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
10 REPLIES 10
rob2218
oh and the door is a "D1 tramsom 17" type door. if that helps to resolve where I can change the color of the transom frame.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
by the way...here's the clients comment. Where or where is the parameter to change that transom's color???? material?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
Using AC17 with Library Updated it is controlled by the Leaf Surface Setting which by some reason you are missing from your door.
Do you have the latest library update for 17?
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
rob2218
hummm.....I'll have to check the latest AC17 library updates...maybe that's the problem?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok...so my AC17 Library is "up to date".
But here's something I had failed to mention.
The "door panel" is a "custom" door panel.
I had to create a "dutch type" door panel....though I don't see how/why the door panel being custom would affect the transom parameters?
Maybe I'm not allowed by the program to have a "custom door panel" where I can alter the transom above?
is that correct?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
could the "custom door panel" have freaked out the parameters for the transom?? shouldn't have right? I mean..I can have a door panel that's custom yet the transom be from the D17 transom object?...No?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
well....and here we have it!
it appears that I CAN NOT use a custom door panel without disturbing the parameters of the transom above in this object.
as soon as I changed the panel back to a stock panel selection that WAS NOT custom...those "leaf parameters" returned to my list of adjustable parameters......what a bummer.....seems I can't have my cake and eat it too...
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
Just a thought:
• change panel to regular
• edit material
• change the panel back to custom
or just create a custom panel that includes the transom and then use the regular door?
AC27 US/INT -> AC08
another Moderator
rob2218
at this point sir.....I'm gonna try anything.
i>u
Edgewater, FL!
SOFTWARE VERSION:
