Unable to display asymmetric double door - one small, one large door leaf
The problem is that one-and-a-half doors in 3d and 2d are displayed as double doors. In my opinion, the matter is that in the door parameters in the "Shutters" section there is only one state of the "Location" parameter, namely, "Symmetric". As I understand it, there is no possibility to put the shutters asymmetrically (one large and one small shutters). If anyone knows how to send a report to the developers, I would be very grateful.
I work on the 24 version of Archikad.
My mail for communication: gaster3t at gmail dot com
[email edited by moderator to make it slightly less likely a spambot would skim it]
I will report this to the developers.
Minh Nguyen
Dear Drike,
Thank you for your question and I am very sorry about the issue!
I tested the mentioned issue with Archicad 24 INT 3008, unfortunately I was unable to replicate it. As you can see, the Asymmetrical option is available in the Shape section. I am wondering if this is the right door object that we are talking about? Which language version are you using, and what is the name of that object in your version?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Guru
Re-title to do asymmetric door shutters?
