Learn more
jc4d
Volume calculation label for House Model
Is there a way to use a label to calculate the volume of the built-in house model object?
I'm familiar with GDL is that's the only way to do it.
Juan.
11 Replies 11
Sorry I forgot all about it.
It seems that it is calculating (only for NET volume) just the volume of the roof when you have a roof turned on.
With a flat roof and a 5.0 x 5.0 x 5.0 house, I get the correct 125m³.
But turn the roof on and it give just the volume for the roof.
I have no idea why it is doing this.
But as I mentioned, I didn't think you could get volumes for objects unless it is calculated in the object itself (which is not usual).
I did find this in the reference manual, and it conspicuously does not mention volumes for objects.
However, convert it to a morph.
It will actually create 2 morph elements (building and roof).
Union them together and you now get the correct volume (I think - I didn't actually calculate it).
But oddly I couldn't get the 'morph volume by storey'.
jc4d
Thank you for the detailed explanation.
Would be nice to know what is happening behind the scene with the volume calculation (from a Graphisoft dev). But I can work with the information you provided.
Juan
