missing doors
hi-
when i opened a 19AC project in archicad 20 all doors are missing -i tried both migration choices but the same problem...any idea???
11 REPLIES 11
David Maudlin
kinan mohammed:
Does the Library Loading Report show missing library parts? If so, then try loading the same libraries that where used with the AC19 file. If not, then two possibilities are Renovation Filters or Model View Options (MVO > Options for Construction Elements > Door Options). Are the doors missing in 2D, 3D or both?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
yes there is missing library parts....but isn't migration library would solve this issue as before? why i have to add Ac19 file library?????
David Maudlin
kinan mohammed:
If you post screen shots of the Library Loading Report (showing the missing library parts) and the Library Manager (showing the loaded libraries), someone may be able to tell where the problem is. It may take two posts to post two images (one image per post limit).
Eduardo Rolon
Take in consideration if the project was started in a specific localized AC version and then you open it in another (or upgrade to another) then Migration assistant might not be able to upgrade them. For example if I have a project started in AC19-US and then open it in AC20-INT then I'll get missing items.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
ejrolon
both version is INT AC
Here's the Library Loading Report
OK we can see you missing library parts and also that you have duplicated library parts.
Can you please show a screen shot of the loaded libraries as well?
loaded libraries
I can't quite see from your image but I assume the migration library that is loaded is the 19 migration library?
Do the doors have anything to do with the missing ASU library (I am not familiar with this one).
If the door come from there than that is why they are missing.
Or you could try as David suggested.
Delete the 20 library and the migration library and load just the 19 library.
If that works then there is a problem with the migration library.
If it doesn't work then I would guess the doors are in the ASU library.
David Maudlin
kinan mohammed:
Did you use the Migration Assistant when opening the file?
