problem: morph lines not showing | waffle slab | rib + coffered + caisson | smart way to waffle slab
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-08-25
12:16 AM
2023-05-23
04:06 PM
Rubia Torres
i convert this object to the morph.
but i want it to appear that hidden lines as when it was an object.
there should be hidden lines in the morph.
how can we achieve this?
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-28 01:09 AM
I have attached a module file which you can place as a Hotlink module and then embed to see what's going on. Hope it helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-25 09:25 AM
Did you add this script into your object 2D script after deleting the script automatically generated by Archicad ?
Project2 3,270,2
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-25 11:24 AM
For what reason are you needing to explode the object to a morph?
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-26 08:59 PM
Christophe wrote:valar morghulis Christophe Fortineau,
Hello aryastark,
Project2 3,270,2
no, i didn't.
um, and how can i add that script into that objects 2D script? and what it that for?
Memory: 16384MB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-26 09:05 PM
Lingwisyer wrote:trying to do waffle slab with "precast double tee" object. but after placement it must be split with line and spline. due to being an object, it doesnot split flexibly, even cutting is not allowed at all.
As far as I know, in a Morph, you cannot. There is no control of 2D Linetypes as you just see a Projection or Cut of the said Morph. There is no Symbolic representation.
Ling.
so after it multiplied several times horizontal and vertical, the whole objects stack mass should be split at the same time. that's why it should be morph.
Memory: 16384MB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-27 11:44 AM
... what it that for?I guess I did not really understand your aim.
To do a "precast double tee" you should try to do beams with your own profil.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-27 03:15 PM
Christophe wrote:thanks, but...
Memory: 16384MB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-27 04:01 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-27 09:45 PM
DGSketcher wrote:thanks, i can't understand how can we create waffle slab with complex profile beams.
I think your answer lies with a slab and form the waffle grid with complex profile beams. If you use the same material they should all merge. The next bit to fix this is to look at your Model View Options (MVO) where you can control the appearance of the beams below the slab. You can also hide the blue axis line highlighted in your image in the MVO settings.
because waffle rib slab is not constant with it's section.
complex profile creates from section but waffle slab has voids and occupancies while going along the z axis.
so we can not draw it from section(with complex profile).
archicad team should make waffle tool indeed like this->
look at this man->
look his devious and indirect and tiring and funny and joking and boring and fixed and unchangeable way to do waffle slab.
He is struggling, he is in pain.
i will not do this with that excessively long methods. it is laborious.
for 2 days i couldn't find single smart way to build waffle slab.
there should be something. something...
i will find it, and share with you. stay on hold...
ps: these methods are garbage too. ->
Memory: 16384MB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-28 01:09 AM
