storefront door
Is there a way to have the lower rail on a storefront door that has a sidelight be different than the lower rail of the sidelight? I want a 10" rail on the door and 2" on the sidelight. The only way I've seen around it is to have a storefront door with out a sidelight with a storefront window adjacent to it. Any help would be appreciated.
Thanks.
1 REPLY 1
the object seems to use the same parameters for door and sidelight frame dimensions. I'm afraid you have to stick with door and window side by side.
