Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
License Manager Old Install file
Brett Brown1
Hi, anybody got an old version of the License Manager Tool instal file that they could send me. One for High Sierra.
The only one on the graphisoft website installs an incompatable codemeter driver that doesn't work on High Sierra.
PS I'm not a newcomer but this stupid version of this website won't let me log in to my account
11 REPLIES 11
Lingwisyer
Guru
If you can't find a GS source for it, might you be able to use the user runtime from Wibu?
Its the Graphisoft License Manager problem as the only version that installs and is not compatible with the old codemeter version that came with the original 20 software. attached is the error. The new codemeter version will not install on High Sierra. Hence why I need an old version of the Graphisoft License Manager install file. Hoping someone will have it lying around on an old computer
That message doesn't look like a problem with the License Manager.
it is telling you the Codemeter driver is not compatible.
Does this help at all.
It seems there is something else you need to do with High Sieara.
https://graphisoft.com/downloads/protection_key
Hi Barry, that is for a Hardware Key correct? I have a software Key. I did try it but no joy. The codemeter driver installed from the original Install disc or download, would have a different codemeter driver version. The License Manager in 2019 was 20.0.0 v1 INT (4800). That worked then and of course the codemeter driver was also different back then.
So can't you uninstall the current codemeter driver?
And then re-install version 20.
That will add back the codemeter driver for that version I am pretty sure.
I am not sure if this is the Codemeter version you are after ...
https://www.wibu.com/support/user/user-software.html?tx_wibudownloads_downloadlist%5Baction%5D=index...
Sorry I know nothing about Macs and am not sure why 10.13 seems different to other versions.
Sorry, that link seems to take you to the 7.6 driver.
Just search for 10.13
6.8 is the driver that installs with the software, which the latest License Manager is putting up the error to. Tried to install the 7.4 and 7.6 drivers but they both freeze up and don't install. So my last option is to get the install .dmg file of an old License Manager. Support isn't interested and Graphisoft don't show legacy versions of the License Manager. Hence the title of the thread.
License Manager is installed with the Archicad install.
So just reinstall 20?
I am not sure if you will need to un-install the current License Manager and Codemeter drives first, as they may not downgrade when you install an older version of Archicad.
